South Atlantic Delaware, Florida, Georgia, Maryland, North Carolina, South Carolina, Virginia, and West Virginia
code 0174
Old Jun 28, 2004 | 09:50 PM
gol10dr's Avatar
code 0174
I have a 96 3.8 v6, with SLP intake, straight pipe(no cat for now), new o2 sensors and a o2 sim. I had the codes 171 and 174 show up and the car seemed like it missed during acceleration.
I replaced the o2 sensors, and cleared the codes. It went about 1/2 of drive time and then a code 174 came back on. I bought several bottles Seafoam, I put one in the gas tank as an additive, I used one and ran it through the vacuum brake booster line. I blew out a ton of think white smoke.
The code went away for about a day then the same code showed up. 0174 was back. Does this mean I have a bad injector in Bank 2? If it is an injector would it be worth have the injectors professionally cleaned, or should I just have them replaced.
Also if i do have to have the injectors replaced they are 22lb/hr, could the stock fuel pump handle 24lb/hr injectors, or would i make a lean condition by doing so.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
