A/C cycling switch question
I'm trying to "jump" the a/c cycling switch to see if mine is bad. There are three wires on the plug, which two do I jump to bypass the switch? For my 98Z...... Thanks K
Re: A/C cycling switch question
not sure you have the right plug
I've always used the two prong plug on the evap canister to engage the clutch........
of course I have a 91 camaro so take that into consideration.....
