LCA Relocation Brackets worth it?
I am planning on installing some new LCAs in my 95 TA. I was wondering if the Relocation Brackets are worth the $$? If they are, which should I get...weld on or bolt on!! I kind of like the coated bolt-ons just because the are coated already!!
Thanks!
Thanks!
Of the 3 cars that I have driven that have them, all 3 of them had better traction after the brackets were installed. Less wheelspin and wheelhop. I say it's worth it. Get the weld-on ones too.
I'll give an alternate opinion that the bolt in ones are ok (at least the BMR ones).
Unless (as BMR told me): "...your car eventually dips into the 10's or you are pulling less than a 1.5 60 ft/time."
Originally posted by Dan95TA
can relocation brackets be used even if the car hasn't been lowered? I was under the impression that they were used to compensate for lowering.
mark0006
Aug 29, 2015 09:45 AM
