LCA Relocation Brackets worth it?
Old Mar 23, 2003 | 09:29 PM
InGodITrust's Avatar
I am planning on installing some new LCAs in my 95 TA. I was wondering if the Relocation Brackets are worth the $$? If they are, which should I get...weld on or bolt on!! I kind of like the coated bolt-ons just because the are coated already!!
Thanks!
Old Mar 23, 2003 | 09:34 PM
Zepher's Avatar
Of the 3 cars that I have driven that have them, all 3 of them had better traction after the brackets were installed. Less wheelspin and wheelhop. I say it's worth it. Get the weld-on ones too.
Old Mar 23, 2003 | 09:35 PM
DjArcadian's Avatar
Yes, they're worth it. It's part of a full suspension system. Get weld in. You can weld in the bolt in type too but they usually come painted and you'll mess up the paint job when welding.
Old Mar 23, 2003 | 10:23 PM
I'll give an alternate opinion that the bolt in ones are ok (at least the BMR ones).
Unless (as BMR told me): "...your car eventually dips into the 10's or you are pulling less than a 1.5 60 ft/time."
Old Mar 23, 2003 | 10:27 PM
Dan95TA's Avatar
can relocation brackets be used even if the car hasn't been lowered? I was under the impression that they were used to compensate for lowering.
Old Mar 23, 2003 | 10:37 PM
They can also be useful for non-lowered cars to improve traction.
Old Mar 24, 2003 | 12:18 PM
Janny's Avatar
Made a very big improvement in acceleration grip when coming off turns on my slightly lowered Z.
Devinfoote87
Feb 12, 2016 03:21 PM
Henson071
Sep 18, 2015 04:01 PM
mark0006
Aug 29, 2015 09:45 AM
realistyc
Jul 28, 2015 07:32 PM
Boss002
Jul 24, 2015 10:47 AM
