torque converter question
it should fit with no problems what is the problem that it wont fit? you do know you have to spin the converter to get it on all the way should slide 3 times as in turn and push it will move about an inch back and keep turning untill it will not go back anymore .. any diffrence in the shape or look the splines should be the same but count to make sure.
ChrisFrez
Feb 15, 2015 07:49 AM
squarehead
Nov 21, 2014 08:02 PM
