1 gen. swap into 94 z28
Do you only have to get electric water pump to use serpentine belt setup off the 94?I got 202 heads no holes other then that it should work?Will power steering pump work on rack and pinion ?my pump is off 72 Monty Carlo any info would be good Thank You
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
