1 gen. swap into 94 z28
Old Oct 18, 2014 | 11:48 AM
rmppainting's Avatar
Do you only have to get electric water pump to use serpentine belt setup off the 94?I got 202 heads no holes other then that it should work?Will power steering pump work on rack and pinion ?my pump is off 72 Monty Carlo any info would be good Thank You
Old Oct 18, 2014 | 07:18 PM
Re: 1 gen. swap into 94 z28
What will you use for a crank pulley/damper? The LT1 unit is neutral balanced. A Gen 1 typically relies on a balance weighted damper/balancer.
Old Oct 19, 2014 | 07:42 AM
cnorton's Avatar
I believe that this statement is true of only the 400 cubic inch Gen 1. What am I missing?
c
Old Oct 19, 2014 | 10:49 AM
I should have said sometimes used on a 383 with a cast crank.....
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
chuyz28
Jan 15, 2015 04:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
cryptopsy
Aug 19, 2002 12:19 PM
