95 LT1 No spark
Old Oct 15, 2014 | 09:08 PM
United_Muscle's Avatar
95 LT1 No spark
I have a 95 Camero ive slowly gotten it back to running condition after trouble with a broken rocker roller. The car ran great for a week then decided to blow a hose from the water pump. replaced the hose and it ran great for two days and would no longer start.. ITS GETTING NO SPARK.... I have replaced the opti the ICM and the coil along with the wires.. i have ran a few test the car IS sending a pulse to the injectors the icm harness is also getting power but its getting 7v on dc and 4 on ac while turning over.. i have ran out of hope any ideas
Old Oct 15, 2014 | 10:12 PM
Re: 95 LT1 No spark
Getting 7v on what test? If it is supposed to be system voltage (closer to 12v) something is wrong, there.
Old Oct 15, 2014 | 10:47 PM
GaryDoug's Avatar
Prominent Member
Re: 95 LT1 No spark
Which ICM terminals did you measure with those results? I assume the 4 volts ac was terminal B (white wire). Was the 7 volts at terminal D (white/black wire) while cranking?
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
