In the middle of an opti change...
Old Sep 14, 2014 | 03:36 AM
16Sammy61's Avatar
Anyone know where i can get the temperature sensor for the head?(and connector). It appeared it was snapped when i removed it already.
I will need a new MAF connector too. It it just a plain 3 wire pigtail?
Also im replacing the radiator, and i can take the coolent level sensor and move it to the new correct?
Old Sep 14, 2014 | 09:45 AM
Re: In the middle of an opti change...
Shoebox has part numbers for items like that.
1993-1997 F-Body Part Number Collection
MAF sensor pigtail and single wire coolant temp sensor pigtail are in the table on the right side of the page.
Temperature gauge for the head (how did you break that changing the OPTI???) is in the parts table on the left side of the page.
Coolant level sensor can be reused.
Old Sep 16, 2014 | 11:43 AM
raroz28's Avatar
I got the coolant sensor in the head and water pump from advance auto parts - normally stocked item.
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
jayblev95
Sep 26, 2015 09:44 PM
cmsmith
Sep 14, 2015 09:25 PM
