2000 s10 with lt1 motor backfiring
Old Jun 12, 2014 | 02:11 PM
ozarks motors's Avatar
lt1 motor in 2000 s10 backfiring
I have a 2000 s10 with lt1 motor in it that is backfiring. new distributor, plugs, wires, cap and new fuel pump. Injectors are not leaking. Any suggestions as to what is causing it to backfire.
Old Jun 12, 2014 | 02:50 PM
Dtimekw's Avatar
Re: 2000 s10 with lt1 motor backfiring
Backfiring when? Idle, accel, decel? Is the motor modified at all or is it stock? Did it happen after the new opti/cap/plugs/wires? Basically, when did it start backfiring??
Old Jun 12, 2014 | 03:10 PM
Backfires when idling, when it accels, it is a stock motor. Just bought it. It was doing it before and after the new parts. checked the injectors are not leaking.
Old Jun 12, 2014 | 04:45 PM
Re: lt1 motor in 2000 s10 backfiring
Let's move this to "LT1 Based Engine Tech"..... More likely to get tech help there than you are here in "New Member Introduction".
Have you scanned it for codes? Was it backfiring before you changed out all the parts you list? Have you checked the fuel pressure? Have you checked the valve adjustment? What year is the LT1 engine? What year ECM/PCM are you using? Is the engine stock, or modified? If modified, what has been done?
Old Jun 12, 2014 | 04:49 PM
OK... see you double posted in two forums. I'll merge the two threads.
Old Jun 12, 2014 | 07:17 PM
The engine came out of a 95 camaro. Used factory wire harness with the factory ecm. That's it the only mod is a msd cap and roter bug no rockers been messed with
Old Jun 13, 2014 | 06:59 AM
And, still need this info:
I understand you haven't "messed" with the valve adjustment, but have you checked it?
HectorM52
Jun 23, 2016 08:42 PM
willismoons
Feb 14, 2015 08:42 PM
capebuf
Jan 13, 2015 07:22 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
