need some lt1 help
need some lt1 help
I have a 94 Camaro just swapped a 94 lt1 from am impala as into it. The motor was in my impala and running. I'm using the pcm from the impala that I had tuned by pcm for less which I put into the Camaro. After finding a few issues with the opti and coil I can get the car to fire every time but won't stay running on its own. So I have a few questions. I know the pin outs for the pcm are different but are they different enough to keep the car from running? Also any ideas to keep this biotch running under its own power is much appreciated. No idea is a stupid one.
So:
94 Camaro wire harness
94 impala 383 stroker with pcm for less tuned for impala
Vehicle won't stay running on its own power
Opti, coil, fuel pump all new
And GO
So:
And GO
Prominent Member
Re: need some lt1 help
Was the 94 an LT1 also or was it a V6 engine? I checked the documents for the pin-outs of both. I did not check everything, but it looks like all the important ones are the same: opti, injectors, ECT, IAT, MAP, MAF, fuel pump relay.
Check for trouble codes. Some of the critical ones won't set the SES lamp.
Ya both cars were lt1 cars. So I changed back to the Camaro stuff meaning pcm, injectors, and maf...... still had the same issue so I opened the throttle a bit more with the set screw and it will idle around 1500 and calm down to around 1000ish but will still stall after it calms down more so I'm thinking now I need to set the tps. Also I do have a code that only comes on a few seconds after i start it but when I jump a and b the fans kick on for diag mode but the light doesn't flash
You've got to simultaneously adjust the RPM, IAC counts and TPS voltage to get them within spec. Do you know what pcmforless set the idle at?
If I read your second post correctly you put the Camaro injectors in the Impala 383. Were they the same size as it was programmed for? It's somewhat confusing but it appears you are now running the 383ci engine with the 94 Camaro PCM. Was the Camaro LT1 also a 383 with a similar cam, heads, etc.?
Im all ****ed up.....I just put the stock Camaro pcm stock injectors and tried to get it to idle which wasn't a great idea but I'm starting to get frustrated........I put the correctly tuned pcm back in with matching injectors (from my impala) I do get a check engine light with this pcm (haven't read the code) the car fires but won't run unless my foot is on the gas (back to square one) I'm thinking about sending out my Camaro pcm for a tune
Thanks I needed a good smack upside the head lol.....this is what I got
383 stroker, stock ported heads, stock ported intake, 236/242 cam, 58mm tb, 42lb green top injector, pcm for less tune from my impala which the motor ran fine in that...
I would ask other members on one thing, are the PCMs compatible?
Scan for codes and see what you get. Can we assume the Impala engine/parts ran fine?
