'95 Trans Am Convertible red/white int 139k miles mods
Old Jan 1, 2013 | 04:08 PM
2QUIK6's Avatar
I need to pair down a few more vehicles, this is next to go.
1995 Trans Am convertible with 139k miles for $5300. I have owned this car since 1997 when it had 5100 miles on it. It has been my wife's primary daily driver for years, then it was mine for several years in 2002-2008 when most of the mods were put on the car, then wife started driving it again.
There are several lifetime warranty parts on this car from Autozone and PepBoys that I will list, I have full documentation of just about every part on the car. I have a history log of everything ever done to the car and when it was done, maintenance, etc.
It does currently have oil leak at the water pump drive shaft, I put a new seal in it but it continues to leak, I may have torn the seal or something putting it in, it seems to leak less the longer the seal has been in. I just replaced the optispark also with a Delco unit, put a new waterpump on it also while it was apart. The old opti's rotor screws fell out and it started fine before that.
It also will need new tires.
Small crack in paint on rear bumper, see pic.
Paint chips on front facia, although it has been painted a time or two in its life, but never wrecked in the front. Has been bumped on the rear several times in my wife's work parking garage and repaired.
All other paint is in great shape.
Interior is in good shape for its age with the exception of the driver side bloster, see pics.
Convertible top is in good shape, but has some discoloration and some small cracks in the seams, but does not leak. Has been garage kept and parked in a parking garage at work, hardly ever left out. Top is original and is a hard type vinyl material rather than a cloth type material like some tops I have seen.
There is nothing that does not work on this car, the passenger side window is very slow to roll down/up however. AC /heat is fine, headlight motors are fine.
I do have a set of Simmons OM wheels and fairly new Nitto tires that are extra if wanted. 17x11 rears with 315/35/17 tires and 17x9 fronts with 275/40/17 tires, they were $4700 new, extra $1500 takes them.
Has the original floor mats, original stereo and steering wheel controls work fine.
Also has a 10 disc CD changer in the trunk with controller beside seat.
Here are the parts I have a lifetime warranty for if they ever need replacing again with paperwork:
-Water pump
-driver side power window motor
-passenger side headlight motor
-rear brake pads (not sure how this works but from Autozone)
Mods include:
-BMR sub-frame connectors
-BMR front and rear sway bars and pan-hard bar
-Lloyd Elliot LE1.5 heads
-LPE 211/219 cam
-Crane Gold 1.6 SA roller rockers
-Port matched and ported intake by LE.
-LT4 HD timing chain
-Kooks stainless long tube headers
-2.5" true duals over the axle
-Spare set of cats that bolt right in for emissions testing (ones on the car are hollow because they will hit on speed bumps and break the insides)
-Stock untouched rotating assembly
-Brand new NGK TRX55 IX Iridium spark plugs, just installed
-Ram air intake and fiberglass ram air hood
-Transmission rebuild about 30k miles ago, performance build by Jack Laswell in Dallas.
-Aluminum transmission pan with drain plug
-BMR LCA with poly bushings
-BMR shock tower brace
-Bilstein performance tuned shocks
-TA Rear differential cover
-3.42 rear gears
-LT4 composite valve covers
-Larger LS1 front brake conversion
-Newer center interior console that has the extra cup holder and better console lid.
There may be more that I can't think of, will add if I remember more.
PM me for my number to discuss further, thanks
Here are the pics:
Rock chips in front facia:
Continued on next post....
Old Jan 1, 2013 | 04:09 PM
2QUIK6's Avatar
Re: '95 Trans Am Convertible red/white int 139k miles mods
Driver bloster tear:
Old Jan 1, 2013 | 04:10 PM
2QUIK6's Avatar
10 disc CD changer in trunk:
Paint crack on rear bumper:
Tail lights have some fading or some type of separation at the top:
Top close ups:
Old Jan 1, 2013 | 04:11 PM
2QUIK6's Avatar
$5300 for car as-is. $1500 for Simmon OM wheels and Nitto's, rear rims have some slight curb rash and a very small flat spot where the ATM curb was hit, curb was sharp edged.
This rims has the slight flat spot at the 9 o'clock position
Custom made center caps with firebird on them:
How they look on car:
$5300 without Simmons wheels, $6800 including wheels.
I also have the original hood, intake duct, cam if interested, and various spare parts including another opti, side mirror and such to sell extra.
PCLZ28
Dec 24, 2015 05:19 PM
rockync7
Jan 1, 2015 05:10 AM
joe777107
Dec 1, 2014 09:32 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
