97 Z28 Gas In Oil
Old Jun 14, 2012 | 01:49 PM
weedog's Avatar
97 Z28 Gas In Oil
i have another post on here that i posted the other day about another problem i have with the car i checked the oil on it today and it smells like gas real thin and way over full where could the gas be coming from the other problem i had was i pressure washed the engine one day it cranked find pulled it in garage about 3 weeks later i went to pull it out to get the mower out and it took about 30 to 40 secs to start and when it did it had a smell and was missing i dont drive it much about 1500 miles in last 3 1/2 years its the LT1 could someone help me out.
Old Jun 14, 2012 | 02:18 PM
96capricemgr's Avatar
Re: 97 Z28 Gas In Oil
Stuck open injector or bad fuel pressure regulator leaking through the vacuum line.
Disconnect the vacuum line and prime the engine by turning the key on but do not start it. If you get no fuel there then it is probably an injector stuck open.
While checking the regulator vacuum line be aware that if the regulator is leaking you could theoretically cause gas to squirt out from the vacuum port or line, maybe cover it with a clean rag and then check the rag for gas. Take precautions not to get hit with it and not to ignite it hence NOT STARTING THE CAR.
Old Jun 14, 2012 | 03:44 PM
weedog's Avatar
where is the fuel pressure regulator at on the 97 Z28 and allso where is the vacuum line at Thanks Again
Old Jun 14, 2012 | 05:40 PM
regulator is on the back of the intake right where the fuel lines come and go.
The vacuum line runs from it to the passenger side of the intake manifold. There are two vacuum lines going into the intake on the passenger side, one is for the HVAC the other for the fuel pressure regulator.
Old Jun 14, 2012 | 09:18 PM
weedog's Avatar
found it thanks
F'n1996Z28SS
Aug 23, 2023 11:19 PM
rideordie
Nov 5, 2019 04:52 PM
Deadbolt24
Jan 19, 2015 01:29 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
