97 Z28 problem after cleaning engine
Old Jun 7, 2012 | 11:48 AM
weedog's Avatar
after cleaning engine car cranked fine pulled in garage and after about 2 weeks went to crank car and it spun over for about 30 to 40 secs before starting then had a miss and a bad smell what could have got wet to cause it to do that THANKS
Old Jun 7, 2012 | 01:42 PM
Re: 97 Z28 problem after cleaning engine
Getting the Optispark distributor wet will often cause problems like that. Did you protect the Opti before cleaning the engine? How did you clean it?
Old Jun 7, 2012 | 09:35 PM
weedog's Avatar
cleaned with engine cleaner and i did not cover the opti dist is there a way to dry out the opti dist thanks again
Old Jun 7, 2012 | 10:42 PM
mrmint69's Avatar
The vented opti's are designed to pull moisture out of them with the car running. If you can get it to run, maybe it will just take a little time to straighten itself out and be just fine. Corrosion is bad and letting them sit with moisture in there can ruin them over time.
NorthPoleDev
Dec 31, 2014 03:20 PM
Jazsun
Dec 29, 2014 12:14 PM
nophix
Nov 30, 2014 10:26 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
