does the knock sensor go into coolant or oil? LT1
Old May 30, 2012 | 06:52 PM
coreylt1's Avatar
probably a stupid question but does the knock sensor go into coolant or oil?
just went to remove the plug to install my knock sensor and the piece of **** stripped on me
going to attempt to fit a drill in there and drill it out...hoping the other side goes into coolant and not oil so i dont have to drop the pan for the second time to remove metal shavings
thanks in advance
Old May 30, 2012 | 08:01 PM
96capricemgr's Avatar
Re: does the knock sensor go into coolant or oil? LT1
coolant
Old May 30, 2012 | 10:33 PM
coreylt1's Avatar
Originally Posted by 96capricemgr
coolant
thank you sir
Old May 31, 2012 | 09:39 AM
bobdec's Avatar
There is a 'block drain plug' in the same position on the opposite side of the block in the F-bodys. Some of the B-body's use it for a two KS setup. Never heard of using it for a single F-body KS operation. Not even sure if it's physically accessible in your setup, or if will react the same wen detecting knock as the original position. Just a wild thought...!!!
Old May 31, 2012 | 10:35 PM
coreylt1's Avatar
yeah the guy who put my block together put a plug in both sides, i tried to remove the plug and stripped it out and had to drill it out on an angle to get the easy-out in there.. its a tight spot for a drill but i got it. passenger side by the starter
HectorM52
Jul 30, 2017 11:46 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
Nostang 96z
Sep 10, 2002 08:54 PM
96z
Sep 5, 2002 07:53 PM
NJ SPEEDER
Jul 19, 2002 10:22 PM
