LT1 cluster bulb layout
Old Apr 14, 2012 | 01:11 AM
blue 79 Z/28's Avatar
anyone know the layout of the lights in the back of the cluster? like what socket goes to what part of the cluster/warning lamp? thinking about doing an LED conversion with super bright led T10S-TW twist sockets and 9mm wedge base LEDs. but i don't want to change every one, i want to eliminate a few warning lamps in the process like tcs, low trac, check guages, skip shift (auto), e brake, abs (abs delete) etc.
Old Apr 14, 2012 | 01:05 PM
Re: LT1 cluster bulb layout
I think what you are asking for is a pinout. Shoebox has that:
http://shbox.com/1/95_z_cluster_pinout.jpg
I'd definitely think twice before deleting the "BRAKE" light. It's for more than the E-brake. It also turns on to warn you that there is a difference in the hydraulic pressure between the front and rear braking system. Even with the deletion of the ABS system, preserving the switch is possible.
Old Apr 14, 2012 | 01:30 PM
no i mean like this, what bulb feeds what on the front, not the specific pinout for the harness signals:
Old Apr 14, 2012 | 04:13 PM
Couldn't you just hold a small light behind each hole and see what lights up?
Old Apr 15, 2012 | 01:05 PM
good idea, ill have to sit in the dark with a flashlight
rwferguson43026
Feb 6, 2015 10:06 AM
sdn1997rs
Dec 30, 2014 08:30 AM
Joes96z
Dec 13, 2014 07:48 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
