LT1 cluster bulb layout
anyone know the layout of the lights in the back of the cluster? like what socket goes to what part of the cluster/warning lamp? thinking about doing an LED conversion with super bright led T10S-TW twist sockets and 9mm wedge base LEDs. but i don't want to change every one, i want to eliminate a few warning lamps in the process like tcs, low trac, check guages, skip shift (auto), e brake, abs (abs delete) etc.
Re: LT1 cluster bulb layout
I think what you are asking for is a pinout. Shoebox has that:
http://shbox.com/1/95_z_cluster_pinout.jpg
I'd definitely think twice before deleting the "BRAKE" light. It's for more than the E-brake. It also turns on to warn you that there is a difference in the hydraulic pressure between the front and rear braking system. Even with the deletion of the ABS system, preserving the switch is possible.
Darth Xed
13
Jul 22, 2002 12:45 PM
