Running wire through the firewall
Old Feb 24, 2012 | 06:53 PM
GMC5.3's Avatar
Anybody got a good spot to runn a 20 gauge wire from pcm to interior? Thanks
Sent from my SGH-T839 using Tapatalk
Old Feb 24, 2012 | 07:58 PM
96 Z 28's Avatar
Re: Running wire through the firewall
IIRC There's a Grommet on the passenger side that dumps right into the passenger compartment under the glove box.
Old Feb 24, 2012 | 10:36 PM
Shoebox has a photo/writeup using the grommet behind the PCM:
Firewall Wire Feed
I've also used a hole that I drilled in the firewall behind/below the brake booster. The hole can be drilled from the passenger compartment side of the firewall. I can send you a photo showing the location.
Old Feb 24, 2012 | 11:13 PM
GMC5.3's Avatar
Firewall Wire Feed
I will take the photo and thank you for sending me the link to shboxs article, seems there are a ton of things i dont see (or look hard enough) on his page
Old Feb 25, 2012 | 11:11 AM
I uploaded it to my website - link below. Look for the black grommet with a wire loom and a separate red wire going thru it. If you pull the driver's side carpet out from under the rubber flap that keeps it at the firewall, you can drill through. Just reference the location of the hole off the centerline of the brake booster, which will allow you to measure down and over from the rod that goes through the firewall from the brake pedal to the booster. I don't remember much more than that.... I drilled that hole about 16 year ago when I installed my first nitrous system.
http://www.injuneer.com/images/photo...e/DCP04224.jpg
Old Feb 25, 2012 | 10:01 PM
Based on your questions, I will certainly agree with that.
Old Feb 26, 2012 | 04:16 PM
GMC5.3's Avatar
You know you would be bored without me shbox
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
89 iroc zl1
Jan 14, 2015 02:18 AM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
