Squeaking Noise Going over Bumps and while Turning.
Old Sep 21, 2011 | 08:46 PM
Kurt Crosbie's Avatar
It's been getting worse over the past year. If I'm sitting still and turn all the way to the left or right, it squeaks near the extremes. Other than that, I notice when I'm backing out of the driveway that it starts to squeak and seems to go along with up and down movement. I'm not sure why it would make the same kind of noise while turning the steering wheel to the extremes and while the chassis experiences up/down travel.
I'm sure one of you suspension specialists know what the heck is going on here. My wife uses the car as a daily driver with a 40mi/day commute so I'm pretty concerned.
Thanks.
Sent from my SCH-I800 using Tapatalk
Old Sep 21, 2011 | 09:56 PM
vangill's Avatar
Re: Squeaking Noise Going over Bumps and while Turning.
have u tried greasing anything yet?
Old Sep 21, 2011 | 10:19 PM
Where do I start?
Old Sep 21, 2011 | 10:38 PM
vangill's Avatar
sounds like everywhere, any front end grease fittings u can find, and do the front sway bar mounts too, those squeak on mine all the time
Old Sep 22, 2011 | 11:27 AM
So I can just pick up a grease gun from Advance Auto or something and just start plugging away?
Old Sep 22, 2011 | 02:17 PM
vangill's Avatar
or u can take it to like an oil change place and they can lube it up if u wont want to do it yourself
Old Dec 11, 2011 | 08:05 PM
AZ_Z28's Avatar
Mine's having the same issue. Am going to get it check out tomorrow. Will post findings.
Old Dec 12, 2011 | 07:14 AM
Most all of the factory front end joints are "lubed for life" and have no grease fittings. Anything that has been replaced may have grease fittings. Otherwise, it may be time for some replacement work to be done. Sway bar bushings would be one thing you could take apart and grease.
Old Dec 25, 2011 | 02:25 PM
jloshotz's Avatar
Survey says?
Jeff1904
Jun 5, 2016 05:00 PM
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
colts0455
Jul 7, 2015 07:19 PM
