SLP Rear Bump Stop Spacer Dimensions
Old Aug 22, 2011 | 08:31 AM
jordankeck's Avatar
Question SLP Rear Bump Stop Spacer Dimensions
Does anyone know the specific dimensions of the SLP spacers pictured below? I will be making a set of spacers and and would really appreciate if anyone that knows could provide any information. The most critical dimensions will be the step and the overall thickness.
Thanks!
Jordan
Old Aug 22, 2011 | 02:19 PM
Re: SLP Rear Bump Stop Spacer Dimensions
Why are you adding spacers?
Old Aug 22, 2011 | 03:06 PM
jordankeck's Avatar
My OEM bump stops are destroyed and I am having issues with my ZR1 wheels rubbing on the fender lip. I trimmed the lip but still would like to limit travel, especially since the car is pretty low (approximately 1.75" below stock).
Old Aug 22, 2011 | 05:04 PM
The only thing is when is sits down on the stops, it's gonna ride like a slammed Datsun pickup.
Old Aug 22, 2011 | 05:05 PM
Old Aug 22, 2011 | 07:09 PM
Stopping the rear of the car from moving up and down, defeating the purpose of the suspension isn't the way to solve the problems.
What width/offest wheels are you running in the back? What tires - brand and size?
Does it rub on the innner fender lip on both sides, or only on one? Have you tried rolling the lip upward? Under exactly what circumstances does it rub?
I'm running some meaty 315/35-17 BFG Drag Radials on my 17x11.0" 50mm offset ZR1 wheels, and the only time the fender lip would rub was when I would throw a totally abussive shift with the McLeod Street Twin. I just rolled it up and the problem went away. The rear of the car has been recentered over the rear axle, using an adjustable panhard rod.
Old Aug 23, 2011 | 09:24 AM
jordankeck's Avatar
The wheels are GM ZR1's on all four corners. The tires are Kumho 712's that I had on my 97 SS and they never rubbed (the car did sit ~3/4" higher than this 93 does).
As I said in my second reply, I did trim both lips so the rubbing is no longer an issue. The issue now is the axle slams into the body without any bump stops. I also re-centered the axle with an adjustable panhard bar.
I guess my question to you Injuneer is what would you suggest I do for the bump stops? Would you cut away the lip on the car and mount the bump stop flush? Should I have a spacer made that equals the 5/8" difference in height from the stock bump stop to the ES bump stops that I have so that the final distance from the axle to the bump stop is identical to an OEM configuration?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
novaiiman
May 15, 2016 11:36 AM
QuickSilver02
Apr 7, 2015 11:12 AM
94Camaro
Feb 28, 2015 03:00 PM
