wierd noise on take off...
Old Jul 28, 2011 | 03:23 PM
gitchuone3439's Avatar
the best way to describe this is everytime i take off hard and the backend sinks it feels like my driveshaft/u-joint is grinding against the bottom of my car....I bought the car lowered on eihbach springs lowered 1.25 in front and 1.50 in the back...it will grind like that until the cars momentum gets going and the backend lifts back up...thinking bad shocks?...I put the car on ramps and looked underneath and it deff. seems like there isnt enough room between the drive shaft and body of the car...looks like they had put an aftermarket "oversized" drive shaft on the car to be honest...
Old Jul 28, 2011 | 06:31 PM
Re: wierd noise on take off...
Did they install LCA relocation brackets to adjust the LCA's to the correct angle? Did they install an adjustable panhard rod to recenter the body over the rear axle?
Did you see any indication the driveshaft if rubbing? Just how large (diameter) is what you describe as "oversized"?
Old Sep 6, 2011 | 01:35 PM
hey sorry for the extremely delayed responce, I have been really busy and havent been able to get back to the computer lol but im freed up now...no from what i see they still have the stock panhard rod and no new lca relocation brackets...this would cause the noise?
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
GT what?
Jul 14, 2015 10:17 PM
colts0455
Jul 7, 2015 07:19 PM
