What is the cheapest adjustable fuel pressure regulator?
Hey everyone, just wondering who makes the cheapest adjustable fuel pressure regulator, and what everybody thinks of the different brands. Thanks!
Why do you need one? The PCM will adjust injector pulsewidth shortly after you modify the pressure, so any changes will be negated. :)
Originally posted by RamAir95TA Why do you need one? The PCM will adjust injector pulsewidth shortly after you modify the pressure, so any changes will be negated. :) I just ordered an AFPR (Racetronix fuel pump upped pressure to 46psi) - I went with the Aeromotive AFPR. It is $140, but I had bad luck with a cheaper one a couple years ago. Thought I'd just buy the best piece that will even work in a blown environment (ups FP based on positive manifold pressure, AKA, boost). -Alex |
Even on a stock car? :confused:
Get whats called the "Hat Kit" from TPIS for 50$
Originally posted by RamAir95TA Even on a stock car? :confused: In that respect, you are correct. But, who's stock? :D -Alex |
Originally posted by AlexA I' In that respect, you are correct. But, who's stock? :D -Alex |
Originally posted by RamAir95TA bad96firechikin (the original poster) is. ;) -Alex |
Look at his sig one more time...;)
'96 Trans Am, Stock as a block; 17X9.5 GMMG ARE 200S Wheels; MAC Progressive Rate Lowering Springs The 355 is in the process. :) |
I've been using the Metco AFPR. You just take apart the stocker and add the parts to make it adjustable. Pretty simple and works great. I think it was around $65.
Originally posted by RamAir95TA Look at his sig one more time...;) '96 Trans Am, Stock as a block; 17X9.5 GMMG ARE 200S Wheels; MAC Progressive Rate Lowering Springs The 355 is in the process. :) -Alex |
How do you know it is?
;) Enough of that...lol |
The cheapest is home-made. You can find it at Projecttransam.
Actually I was askin' fer the new motor. At the moment there is no motor :( It's been parked since November.
You may now call me stupid. :)
