What is the cheapest adjustable fuel pressure regulator?
Old Feb 16, 2003 | 11:01 AM
bad96firechikin's Avatar
Hey everyone, just wondering who makes the cheapest adjustable fuel pressure regulator, and what everybody thinks of the different brands. Thanks!
Old Feb 16, 2003 | 11:05 AM
RamAir95TA's Avatar
Why do you need one? The PCM will adjust injector pulsewidth shortly after you modify the pressure, so any changes will be negated.
Old Feb 16, 2003 | 12:15 PM
AlexA's Avatar
There are legit reasons to adjust FP that will not be adjusted away by the PCM. I wrote up a huge piece about a week ago if you want to dig it up and read it.
I just ordered an AFPR (Racetronix fuel pump upped pressure to 46psi) - I went with the Aeromotive AFPR. It is $140, but I had bad luck with a cheaper one a couple years ago. Thought I'd just buy the best piece that will even work in a blown environment (ups FP based on positive manifold pressure, AKA, boost).
-Alex
Old Feb 16, 2003 | 12:18 PM
RamAir95TA's Avatar
Even on a stock car?
Old Feb 16, 2003 | 01:12 PM
Grease's Avatar
Get whats called the "Hat Kit" from TPIS for 50$
Old Feb 16, 2003 | 01:25 PM
AlexA's Avatar
I'd say it is not useful on a stock car unless you use WOT blocker, then you could lean out WOT without the PCM interfering. Not the right way to do it especially if you are ABLE to use WOT blocker in the FIRST place. LOL
In that respect, you are correct. But, who's stock?
-Alex
Old Feb 16, 2003 | 01:26 PM
RamAir95TA's Avatar
Originally posted by AlexA
I'
-Alex
bad96firechikin (the original poster) is.
Old Feb 16, 2003 | 02:23 PM
AlexA's Avatar
Look at his sig again.
-Alex
Old Feb 16, 2003 | 02:30 PM
RamAir95TA's Avatar
Look at his sig one more time...
'96 Trans Am, Stock as a block; 17X9.5 GMMG ARE 200S Wheels; MAC Progressive Rate Lowering Springs
The 355 is in the process.
Old Feb 16, 2003 | 05:35 PM
Z28ROC's Avatar
I've been using the Metco AFPR. You just take apart the stocker and add the parts to make it adjustable. Pretty simple and works great. I think it was around $65.
Old Feb 16, 2003 | 05:57 PM
AlexA's Avatar
Yes, but how do you know it's not for the new motor!?
-Alex
Old Feb 16, 2003 | 06:16 PM
RamAir95TA's Avatar
How do you know it is?
Enough of that...lol
Old Feb 16, 2003 | 08:26 PM
Dr.Mudge's Avatar
The cheapest is home-made. You can find it at Projecttransam.
Old Feb 16, 2003 | 08:29 PM
Actually I was askin' fer the new motor. At the moment there is no motor It's been parked since November.
Old Feb 16, 2003 | 08:31 PM
RamAir95TA's Avatar
You may now call me stupid.
