brakes for 95 lt1
Old Jun 30, 2011 | 10:38 PM
95_lt1_z28's Avatar
brakes for 95 lt1
hi, im new to this forum; i just recently purchased a lt1 and i want to change the brakes on it, what kind of rotors and pads would u guys recommend, oh yea and there rear disc brakes
thanks
Old Jul 2, 2011 | 02:41 PM
95TA04GOAT's Avatar
Re: brakes for 95 lt1
An LS1 front brake upgrade is a pretty common option. Requires changing the front spindles, calipers, pads, rotors and brake lines. Found used can be a pretty good bang for the buck if you want to increase braking performance.
If it's just time for some brakes and you want a small improvement, regular replacement rotors and some hawk pads will work pretty well.
The LT1 brake setup is pretty weak. It's actually the same brakes that you will find on a Buick or oldsmobile of the same era. I don't know what GM was thinking using the same brakes on their performance line as they do on their old lady grocery haulers.
jb4xx
Feb 2, 2015 10:00 PM
ddr698
Jan 9, 2015 10:05 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
Jul 4, 2005 05:00 PM
vals95z
Mar 18, 2003 03:45 PM
