Rear Sway bar bushings squeaking
Old Jun 19, 2011 | 11:53 AM
copcamaro's Avatar
Help,Help:
I have removed the rear sway bar bushings, cleaned them, lubed them and still they squeak.
I bought a new set of hard rubber ones, lubed them real good and still that DARN squeak persists.
I know this is where the noise is coming from, as when they are off,
"NO SQUEAK"
Old Jun 20, 2011 | 11:03 AM
copcamaro's Avatar
Re: Rear Sway bar bushings squeaking
Originally Posted by copcamaro
Help,Help:
"NO SQUEAK"
Update!!!!!
If this helps anyone having this problem?
I took the sway bar arm off, Cleaned and really lubed the steel bar (2) rubber bushings. Reinstalled the bar and bushings and "Walla" NO MORE SQUEAK!!
When I had the links disconnected (bar connected) no squeak, not thinking "well dummy" the bar is just sitting there with no links connected and it can't move.
It is now so quiet it's unbelievable.
Hope this helps someone.
Old Jun 20, 2011 | 11:22 AM
FirstYrLS1Z's Avatar
I use Permatex anti-seize lube ( the silver crap ) and it keeps the 'squeaks' away longer than anything else I've tried.
HarleyZ28
Oct 5, 2015 06:23 AM
96SilverRam
May 5, 2015 09:56 PM
akwa
Apr 5, 2015 05:09 PM
8T8IROC
Mar 26, 2015 09:02 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
