Need some help with visual identification
Old May 28, 2011 | 02:03 PM
GusarskiSS's Avatar
I have some images that I need some parts identified in. The parts are pointed to with a white stick.
Old May 28, 2011 | 02:08 PM
GusarskiSS's Avatar
Re: Need some help with visual identification
Also for the following
Old May 28, 2011 | 04:55 PM
For the first two in post #1, look at this diagram from Shoebox:
Outer tie rods:
http://shbox.com/1/rack&pinion.jpg
In photos 3, 4, 5, 6 and 7 (which are virutal duplicates, hard to tell exactly what part you are asking about) you are pointing to the rear axle housing axle tube end flanges.
Again from Shoebox:
http://shbox.com/1/rr_disc.jpg
In #8 and #9 you are pointing to the end or the transmission tailshaft housing, where the driveshaft splined slider shaft is inserted.
#10 (last one in post #1) is the trailing end of the rear lower control arm.
In post #2, the photos are duplicates of #8 and #9 in the first post.
Is this some sort of a joke?
Old May 28, 2011 | 07:07 PM
GusarskiSS's Avatar
No, actually my car is in Europe and this is the pictures that a mechanic took from under the car of some parts that need to be changed. I really don't know what the parts are called and he does not know them in English either. That is why I am asking. I need to order them from the US.
As much as I could translate the parts... which he told me...these are the hard translations, I don't know if they are mechanical part equivalents...
end links
transmission semering
persistent bars for rear differential
bearings for semi axle
Old May 28, 2011 | 07:15 PM
GusarskiSS's Avatar
I just redid them so that there are no duplicates. If anyone can please help me out, I would greatly appreciate it.
Old May 28, 2011 | 10:32 PM
So I guess you are saying you don't believe the info I provided? (Which of course no longer matches because you have altered the order of the photos )
Good luck.
Old May 29, 2011 | 07:16 AM
GusarskiSS's Avatar
The order was altered because there was duplicates before. If you want to help, thanks, if not, that's fine too.
Old May 29, 2011 | 08:28 AM
I did help, and you ignored what I said.
Old May 29, 2011 | 10:24 AM
95TA04GOAT's Avatar
Looks like from what is pointed out in the pictures that you need outer tie rod ends, rear lca bushings, axle bearings, and a tailshaft seal.
Old May 30, 2011 | 05:51 AM
GusarskiSS's Avatar
THank you 95TA04GOAT. I really appreciate you helping me out.
Old May 30, 2011 | 11:37 PM
Procharged94Lt1's Avatar
I'm curious as to what mechanic don't know what an outer tie rod end is, axle and driveshaft seals, and bushings are.
Not trying to troll, but even if he doesn't know English, he should know how to get the parts since f-bodies are in Europe too IIRC. Sounds like you are in for a rough time trying to get your car fixed across the ocean by someone who is sending you pictures back and forth to get answers and ideas of what to do.
BTW- It would appear as though Fred gave you good info- and a great source of future info should you need it.
NewsBot
Aug 21, 2015 09:40 AM
Aug 5, 2015 08:35 AM
redleader
Jan 22, 2015 10:11 PM
redleader
Wheels and Tires
Jan 22, 2015 04:20 PM
fordkiller94
Classic Engine Tech
Feb 16, 2003 07:22 PM
