Replaced my injectors, now it takes longer to crank
I replaced my factory injectors with rebuilt FORD SVO injectors 26lb and now it has to turn over several times to crank. Not sure if the O rings are bad or if not using the clips caused the problem but something is wrong. I'm going to quit being lazy and install the clips and possibly replace the O rings but it's weird as sometimes it cranks on the dime sometimes it doesn't but definitely better when it's warm.
Re: Replaced my injectors, now it takes longer to crank
Yeah they line up with one another so it would be hard to mess that up but since you mention it I will double check for the hell of it. Weird cause it started right after I replaced the injectors. Maybe I should pull them and have them tested ?
Not sure what you mean by "line up with one another". There are cylinder numbers on the harness wires.
http://www.injuneer.com/images/photo...ilFuelConn.jpg
Alex Barnes
Jan 24, 2015 10:21 PM
Darth Xed
Jul 1, 2002 03:22 PM
