Replaced my injectors, now it takes longer to crank
Old May 7, 2011 | 01:04 PM
TheBlur's Avatar
I replaced my factory injectors with rebuilt FORD SVO injectors 26lb and now it has to turn over several times to crank. Not sure if the O rings are bad or if not using the clips caused the problem but something is wrong. I'm going to quit being lazy and install the clips and possibly replace the O rings but it's weird as sometimes it cranks on the dime sometimes it doesn't but definitely better when it's warm.
Old May 7, 2011 | 01:05 PM
TheBlur's Avatar
Re: Replaced my injectors, now it takes longer to crank
Don't get me wrong, when it DOES crank the car runs great. Maybe that's an indication when vacuum is created it seals but I'm not sure
Old May 7, 2011 | 01:13 PM
TheBlur's Avatar
It also misfires slightly until it warms up....
Old May 7, 2011 | 01:23 PM
Are you sure you got the injectors harness clips on the correct injectors?
Old May 7, 2011 | 02:08 PM
TheBlur's Avatar
Yeah they line up with one another so it would be hard to mess that up but since you mention it I will double check for the hell of it. Weird cause it started right after I replaced the injectors. Maybe I should pull them and have them tested ?
Old May 7, 2011 | 07:15 PM
Not sure what you mean by "line up with one another". There are cylinder numbers on the harness wires.
http://www.injuneer.com/images/photo...ilFuelConn.jpg
Old May 7, 2011 | 10:01 PM
TheBlur's Avatar
hmmm guess so. Yeah I'll check that then try pulling the injectors to make sure I didn't pinch an O ring.
Noenav
Mar 1, 2019 07:38 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Jazsun
Dec 29, 2014 12:14 PM
Darth Xed
Jul 1, 2002 03:22 PM
