94 Z easiest way to replace lower control arm front?
Old Apr 29, 2011 | 08:09 AM
phonemanstevef's Avatar
Done several searches.....
Anyone?
Old May 2, 2011 | 03:52 PM
TraceZ's Avatar
Re: 94 Z easiest way to replace lower control arm front?
easiest? Plasma cutter.
how rusty is the car?
remove the front wheels.
You'll need to remove the anti-sway bar endlinks from both sides, then tip the sway bar up out of the way.
remove the brake rotor / caliper.
remove the 2 bolts that hold the strut to the lower a-arm
Now you'll need to remove the lower ball joint from the spindle. Removing the hub first makes access to the castle nut for the ball joint easier.
Lastly, remove the 2 bolts that hold the control arm to the engine cradle.
thenewkid
Nov 27, 2014 09:41 AM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
PaulN64
Aug 8, 2002 05:39 AM
PaulN64
Aug 7, 2002 06:17 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
