Failed inspection. Need to replace right front hub... How?
Old Apr 16, 2011 | 01:37 PM
Kurt Crosbie's Avatar
They said its loose and needs to be replaced. How do I go about getting this done?
Sent from my SCH-I800 using Tapatalk
Old Apr 16, 2011 | 02:33 PM
Re: Failed inspection. Need to replace right front hub... How?
Click on the red link in Shoebox's post on the old thread you raised from the dead:
https://www.camaroz28.com/forums/sho...d.php?t=214844
Old Apr 16, 2011 | 08:22 PM
95TA04GOAT's Avatar
Raise and support vehicle, remove tire/wheel assembly, unbolt caliper, remove pad bracket (98-02), slide off rotor, disconnect abs wires, unbolt hub and bearing assembly. Reverse removal to install.
Jazsun
Dec 29, 2014 12:14 PM
fpete1992
Dec 11, 2014 03:51 PM
97QuasarBlue3.8
Sep 15, 2002 06:56 PM
