'78 Camaro Can't hook up!
Old Mar 30, 2011 | 12:15 AM
Z28silverstreak's Avatar
Hello guys!
It's been awhile since I've been on here, and my project has come a long way in the last few months. I've got my engine, trans and rear-end built and in the car, but I have one last problem: no traction! I'm going to use 26x14 slicks in the rear, once I get my suspension figured out. I'm going to put sub frame connectors and an 8 point cage in the car to keep things fairly straight, but what can I use to get that rear suspension to hook like nobody's business? I've got nearly 800 horsies (including nitrous), with a TH350 with trans brake, and instead of burning tires, I'd much rather put my headlights in the trees! Let me know what you guys think!
Old Mar 30, 2011 | 06:55 AM
redneckgames's Avatar
Re: '78 Camaro Can't hook up!
Originally Posted by Z28silverstreak
Hello guy!
so Im assuming that right now you have regular tires. That is the first place to look.
You said you have no traction and that you are GOING TO run slicks. Why do you expect it to hook now without them?
Old Mar 31, 2011 | 12:13 AM
I don't, not by any means. I'm in the process of building the car, and I'm just browsing some setups and I'm sure someone knows what works best. I've got an old set of Mickey Thompson Street ET's that are a 10.5 tire, and I threw them on to see where I'm starting. With nearly 800 horses to the ground, I'm just looking to find what will get my car off the line straight. Wheel lift doesn't really matter, it's expected. Just let me know what you guys think
Old Mar 31, 2011 | 07:31 AM
I got ya now.
I would start out with the basics. Throw some adjustable shocks up front and back, throw on some cal-tracs on the rear. Then hope the rear is built strong enough!
mr28
Apr 20, 2016 05:44 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
sdn1997rs
Dec 30, 2014 08:30 AM
mr28
Nov 23, 2014 11:11 AM
Evilfrog
Aug 7, 2002 11:36 PM
