Suspension/Chassis (Subframe connectors)
I was wondering if anyone knew about this company and how good they are with building Subframe connectors? the company is called Competition Engineering. I am looking to buy Competition Engineering Product # C3108
If you have any good/bad news about them let me know ASAP thank you
Re: Suspension/Chassis (Subframe connectors)
This product is designed to eliminate body flex, and improve both straight line and cornering
performance. Installation can be accomplished in an afternoon with basic hand tools. No modification of the floor pan of factory frame rails is required
This is what their site says about the Subframe connector i need. i hope this is true because if not i am not going to be a happy customer. i ordered one today and should be her by friday so i will let you guys know how it is to install it and ill see if i have mess with the floor pan
Companies like BMR, UMI and Spohn specialize in 4th Gen F-Body suspension parts. While CE makes decent stuff, I don't think they know the 4th Gens like the companies that specialize.
Another vote for UMI here. I bought a set of weld in 3-point SFC's and it's a huge difference, and they fit like a glove with no clearance issues at all. I have kooks long tubes 3" catted y-pipe and a 3" cat back and they clear them all perfectly.
well i bought the CE and they r nice and light but the instructions were not worded correctly and i have a problem with installing them. it says to drill a 13/32 hold in the floor pan to put the bolts through, well that was way bigger than the factory holes on the subframe. in addition, on the driver side i hooked the back subframe to the control arm and then i tried to drill the holes but then i drilled through the floor board but there is another piece that i have to drill through which looks like a triangle, when i tried to drill through it the bit snapped. its hard to explain what i am talking about.
as you can see the triangle piece on the driver side floor pan, i have to drill through the right side slope of that triangle which it is hard when you drill up through the bottle and then try and drill through that. its difficult to explain it
well see i got them mainly to bolt them in due to the fact that i might want to take them off and i do not want to go through the hassle and cut them off. i am hoping i can figure something out.
compartment
Well what is confusing about that? it talks about the driver side then it says drill through the subframe connector and the subframe into the PASSENGER SIDE compartment!? lol In addition, the Bit size is way to big also because i tried to drill up through the subframe connector but i would of made the holes on the subframe connector bigger.
