$200 Ebay Eibach Lowering Springs?
Old Nov 24, 2010 | 02:54 PM
dodge69874's Avatar
Question $200 Ebay Eibach Lowering Springs?
Are these any good? They sell the kits for like $220. I want to get some C6 rims and lower my ride a bit. I figured I would see what was available on ebay vs. the $600+ kits they sell in the stores. What exactly would I need to replace on my ride to lower it about 1"? Maybe lower the front a bit more than the rear. On ebay they sell Eibach Sportline and Prokit kits for like $200. Is that a legit price or could these be a ripoff? Also, what years springs could I use. Like Camaro, Firebird and Trans Am springs from '93 -'02? Thanks.
http://motors.shop.ebay.com/i.html?_...=&_trksid=m270
http://cgi.ebay.com/ebaymotors/EIBAC...item45f6172436
http://cgi.ebay.com/ebaymotors/EIBAC...item2c55b0ca3b
Old Nov 24, 2010 | 03:30 PM
dodge69874's Avatar
Re: $200 Ebay Eibach Lowering Springs?
http://www.ls1tech.com/forums/genera...pension-2.html
Guess I need some shocks too, though I don't think my ride has factory shocks. Previous owner had dropped it but then replaced with factory shocks because it was scrapping on bumps.
Old Dec 9, 2010 | 08:52 AM
edgarda2's Avatar
go to andyperformance something look it up in google there is a slp lowering kit that comes with the shocks an the springs an its slp im thinking about getting that one its 600 an something it lowers u ride for like 1 or 2 inches
Old Dec 9, 2010 | 10:37 AM
94QuasarZ's Avatar
If that one doesn't pan out for you, try Strano or BMR, they're pretty good too.
Old Dec 10, 2010 | 09:51 PM
bluz28's Avatar
Take a look at Vogtland lowering springs, their a better quality then the Eibachs, and you can get them for under $200.
Old Jan 14, 2011 | 01:57 AM
dodge69874's Avatar
I'll most likely be getting C5 Deep Dish rims, Toyo tires, Koni shocks, and Stano springs within the next month. I decided it wasn't that much of a difference between the Strano and Vogtland, so I'd rather have the Stranos even if they are basically the same. I'll post up some pics when I throw everything on. Thanks for the tips guys.
Old Jan 16, 2011 | 03:34 PM
bluz28's Avatar
The difference is spring rate, the Strano's are a linear rate 550 F, 150 R .. The Vogtland are a progressive rate, 440-542 F, 183-228 R ..
BTW Vogtland makes Strano's springs to his specs..
ModdedNerd
Dec 25, 2014 05:51 PM
Dec 1, 2014 08:08 AM
slothgrant
Aug 22, 2002 03:01 PM
MJ_Z28
Aug 8, 2002 09:07 PM
MJ_Z28
Aug 7, 2002 07:15 PM
