le2 heads/cam owners..pushrods?
just had a quick question for you guys running le2 heads w/ the le2.2 cam..do you use the original length pushrods(7.200)? i used a stock pushrod to mock up and it looked about right..but i just wanna be sure..running the mr gasket 5716(.029 thickness)
i marked the top of the valve and rotated the engine over looking to see if the pattern was centered on the valve. i agree as well a pushrod length checking tool is what i need but i was just seeing what most of the le2 packages ran as far as length..
Bignasty85
Mar 3, 2015 04:05 PM
