le2 heads/cam owners..pushrods?
Old Jul 5, 2010 | 11:30 AM
1993Fast_Z's Avatar
just had a quick question for you guys running le2 heads w/ the le2.2 cam..do you use the original length pushrods(7.200)? i used a stock pushrod to mock up and it looked about right..but i just wanna be sure..running the mr gasket 5716(.029 thickness)
Old Jul 5, 2010 | 11:54 AM
Dtimekw's Avatar
How did it look right? How did you check?
Old Jul 5, 2010 | 02:35 PM
RamAir95TA's Avatar
Best thing to do is measure with the right tool.
Old Jul 5, 2010 | 02:49 PM
SS MPSTR's Avatar
This.
Old Jul 5, 2010 | 09:18 PM
1993Fast_Z's Avatar
i marked the top of the valve and rotated the engine over looking to see if the pattern was centered on the valve. i agree as well a pushrod length checking tool is what i need but i was just seeing what most of the le2 packages ran as far as length..
9t4lt4z28
Oct 2, 2015 10:28 AM
Schul365
Aug 25, 2015 05:47 PM
tnorm077
May 23, 2015 09:10 PM
Nutty's96
Parts Wanted
May 12, 2015 09:37 PM
Bignasty85
Mar 3, 2015 04:05 PM
