Why do I keep trashing oil pressure senders?
Third one this time around and it only lasted maybe 4 months. The damn thing starts sticking and is barely responsive.
I also have a mechanical gage under the hood and it is verifying that I do have good pressure so this means the OEM sender is trashed.
Is it the white spring in the pump and 70-80 pounds of pressure at cold startup causing these things top pop?
Is there any other aftermarket sender unit I can use that is more robust?
Jul 4, 2005 05:00 PM
