LSx Patriot Extreme Valve springs BNIB.. 250.00
Old May 20, 2010 | 08:59 PM
ssclone's Avatar
well apparently you cant use LSx valve springs on a sbc so i need these gone. would rather loose some money on it then send it back.
they were never run, tried to install them tonight, and they dont fit.
my loss your gain
http://www.jegs.com/i/Patriot-Perfor...ductId=1122046
# Technical Specs: Install Height: 1.800''
# Max. Valve Spring Lift: 0.660''
# Spring Pressure Closed: 155 lbs. @ 1.800''
# Spring Pressure Open: 410 lbs. @ 1.140''
# Coil Bind: 1.090''
# Retainer Material: Titanium
Patriot Performance's Xtreme spring evolved from our Orginal Patriot Gold. The Xtreme spring is for power adder applications, heads using large valves, and for aggressive cam profiles. These complete spring consists of 16 Patriot Gold dual springs, 16 titanium retainers, 32 Super 7 Machined locks, 16 .505'' ID machined spring bases, and 16 viton rubber seals. This kit will work with both stock and aftermarket rocker arms. No cutting or machining of the stock spring pocket is needed.
*1 kit required per pair of heads.
250.00
i would rather sell these locally, but if you want them we can work out shipping.
buyer pays shipping
aaron
QuickSilver02
Apr 7, 2015 11:12 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
