kind of confused
Old Dec 30, 2009 | 08:41 PM
OneBadRedz28's Avatar
kind of confused
Im looking at some 17x8 rims with a 4.5 backspace. will that make the rim stick out farther or more of a deep dish style? thanks
Old Dec 30, 2009 | 09:36 PM
bluz28's Avatar
I believe you'll need 17 x 8 wheels with a 5.25" to 5.5" backspacing. With a 4.5" backspacing the wheels will stick out to far.
Old Dec 30, 2009 | 11:31 PM
An 8.0" wide wheel with a 4.5" backspace is probably a "0" offset wheel. You need at least a 15mm to keep the wheel just barely under the fender. The stock 8.0" wide wheel has a 55mm offset. Think what that wheel would look like if you moved it 2" toward the outside of the fender.... that's where the 0 offset wheels will sit.
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
94Maroz28
Oct 27, 2015 04:38 PM
Hal Fisher
Sep 30, 2015 09:03 PM
karpetcm
Sep 29, 2015 10:08 AM
