any way to scan a 93 z28
is there any way to scan a 93 z28 other than counting check engine blinks?
i got a bad missfire right off idle once the car has been driven in city traffic for ten miles and needle in temp gauge is right in the middle when it start to miss real bad off idle threw outrpm range and does it some times after 2600 rpms?
Yes
Many of the new OBDII diagnostic tools have provisions for OBDI, or the ALDL port (as ours is called). I have one made my actron, it has detachable leads for ANY make or model, and can even read real time data on an OBDI system, freeze it and replay it. My second job is at Autozone, and if you sweet talk the manager you might be able to score one of their higher end units for a few minutes, they have them there, just arnt supposed to use em.
Charlie
Charlie
Come to think of it...
Run it in open loop all the time, try unplugging the the MAP(or others) to get it to run off factory settings (no sensor input), only if you are in a stranded kind of situation.
If the EGR test doesn't produce the right results, then forcing it to open loop can tell you if you have a closed loop control problem. Which will show up after the engine is warmed up.
Jan 5, 2015 07:14 PM
