any way to scan a 93 z28
Old Oct 26, 2009 | 09:40 PM
The Untouchable's Avatar
is there any way to scan a 93 z28 other than counting check engine blinks?
i got a bad missfire right off idle once the car has been driven in city traffic for ten miles and needle in temp gauge is right in the middle when it start to miss real bad off idle threw outrpm range and does it some times after 2600 rpms?
Old Oct 26, 2009 | 10:29 PM
charliediss's Avatar
Yes
Many of the new OBDII diagnostic tools have provisions for OBDI, or the ALDL port (as ours is called). I have one made my actron, it has detachable leads for ANY make or model, and can even read real time data on an OBDI system, freeze it and replay it. My second job is at Autozone, and if you sweet talk the manager you might be able to score one of their higher end units for a few minutes, they have them there, just arnt supposed to use em.
Charlie
Old Oct 26, 2009 | 10:32 PM
Come to think of it...
Run it in open loop all the time, try unplugging the the MAP(or others) to get it to run off factory settings (no sensor input), only if you are in a stranded kind of situation.
Old Oct 26, 2009 | 11:05 PM
maybe i can talk my boss into letting me use the snap it off one at work since i do all trouble shooting everyone else f-s up lol
Old Oct 27, 2009 | 05:17 AM
TTS makes a version of DataMaster for the 93's.
Old Oct 27, 2009 | 06:47 AM
Any OBD-I scanner with 12 pin cable should work on your car.
Old Oct 31, 2009 | 05:54 PM
thank u box im so used to my obd 2 type data scan software that i was unsure if anything was avilable for the 93's i kinda wanna see whats going on before i do the H/C/intake swap
Old Nov 1, 2009 | 05:13 AM
Guest47904's Avatar
Guest
A typical off idle stumble is caused by the EGR. Easiest way to find out is pull of the vac line off the EGR valve and plug it then try it under the same condition.
While the idea above of forcing it into open loop is a great one. The method described won't do it. The only way to force it into open loop is to unplug at least one of the O2's. No other sensor will force it to open loop.
If the EGR test doesn't produce the right results, then forcing it to open loop can tell you if you have a closed loop control problem. Which will show up after the engine is warmed up.
jayblev95
Jan 20, 2015 01:30 PM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
brentbrowning01
Dec 16, 2014 06:35 AM
Brent94Z
Mar 21, 2002 04:44 PM
