96 Trans Am Ws6 Modded
This is a 1996 Trans Am Ws6 with about 79k miles on it. It is full bolt on, ready for a cam & nitrous. This car sounds amazing and I have recieved compliments wherever I go with it. Over 20k in the car, reciepts and paperwork goes with the car. The wife and I are planning a family, so the car must go. Asking 8,000 OBO.
May also consider a trade for any of the following:
LS1 Z28, SS, Formula, T/A
LT1 Corvette
ENGINE:
LT1 rebuilt top to bottom
LT4 intake manifold
52mm throttle body
1.6 Crane roller rockers
Pacesetter long tube headers (with emissions ports) to 2" chambered exhaust
Heads ported & polished
Manifold gasket matched to heads
Fluid damper
Delteq ignition system.
TRANSMISSION:
T56 transmission rebuilt with Viper Forks
McLeod Performance Clutch
SUSPENSION:
Adjustable Pan Rods
UMI Performance Boxed sub-frames
UMI Performance Adjustable Torque Arm w/ Drive Shaft Loop
BMR Box LCA
LCA & Springs lowered 2"
OTHER FEATURES:
1998 Tail lights
3 Gauge Pod: Water Temp, Oil Pressure, Airflow
t-tops
A/C
Kenwood stereo
All Factory Options
Wolfe Race Craft Cromoly 6-point weld in roll bar Painted Red to Match Car
Racing Seats with 5-point harness
Brake Control with switch in console
Red neons with switch in console (not hooked up).
PLEASE NOTE:
There is a gash down the passenger side from where a mechanics shop ran a lawn mower into it, as well as a small dent and scratched area on the rear passenger side; both from a previous owner. There is a small area with surface rust under the driver's side t-top (t-tops do not leak). The car has typical nose cracks and scratches in paint. Headliner is original and should be replaced, though it is not too bad. I have removed the rear seats, but still have them and they go with the car. Engine Coolant light is on, its a bad sensor, coolant system is fine with plenty of coolant. All records available and go with the car. A set of slicks & skinnies, car cover and a new dash (dash is not damaged, but has some paint marks on it) go with the car. More photos upon request. Serious inquiries only please and no hot rodders please. If you have any questions about the vehicle, you will get a faster response if you email me: harrisb85@gmail.com. I can also be reached on a more limited basis at 407-810-4116. If I don't pick up, please leave a message.
LT1 Corvette
ENGINE:
LT4 intake manifold
52mm throttle body
Fluid damper
TRANSMISSION:
SUSPENSION:
Adjustable Pan Rods
BMR Box LCA
OTHER FEATURES:
1998 Tail lights
t-tops
A/C
Kenwood stereo
All Factory Options
PLEASE NOTE:
whuzizname
12
Jul 22, 2002 07:52 PM
Chris 96 WS6
Jun 27, 2002 05:03 PM
