275/40r17 tire on 17x11 wheel possible??
Old Jun 30, 2009 | 10:25 PM
OneFreakZ's Avatar
Question 275/40r17 tire on 17x11 wheel possible??
like the title says is it possible, i have two tires laying around, my 335 tires are shot..
Old Jun 30, 2009 | 10:33 PM
Most tire manufacturers recommend a wheel width of 9.0" - 11.0" for a 275/40-17. If the tire manufacturer tells you that, for the specific tire you are using, it will be fine. Might look a bit "stretched", since a 275 is about 11" wide, and an 11" wheel is actually about 12" wide when you include the flanges that retain the tire beads.
Old Jun 30, 2009 | 11:11 PM
OneFreakZ's Avatar
how can i find out to see if it fits with the tire manufacturers . tire rack maybe???
Old Jun 30, 2009 | 11:21 PM
OneFreakZ's Avatar
i have two Eagle F1 GS-D3 tires tire rack says (rim width range 9-11'') for the 275/40r17. so i guess im ok right??
Old Jul 1, 2009 | 07:02 AM
Z28avalanche's Avatar
I use 1010tires.com Enter your tire size and it will tell you what size wheel it should be on
Old Jul 1, 2009 | 10:42 PM
Yes. Tire Rack lists the GS-D3 and every other 275/40-17 tire I looked at (maybe 6 or 7) as 9.0 to 11.0"
Old Jul 1, 2009 | 10:45 PM
OneFreakZ's Avatar
awsome ill be mounting tires friday. Injuneer thanks big help
LD Kirk
Apr 30, 2015 08:54 AM
Ken Cemo
Parts Wanted
Jan 28, 2015 09:04 AM
dpw21562
Jan 23, 2015 04:58 PM
Moshbmx1
Jan 20, 2015 03:27 PM
Jason Short
Jan 19, 2015 06:33 PM
