what tire size will fit?
Old Jun 22, 2009 | 10:51 AM
nitrofinch's Avatar
i am currently looking at a set of 18x9 z06 wheels and im wondering what sized tires do i use with those
Old Jun 22, 2009 | 11:53 AM
Z28avalanche's Avatar
I'm running 275/35/18 on all four corners.
Old Jun 22, 2009 | 03:23 PM
z95lt1's Avatar
^^^ what he said
Old Jun 23, 2009 | 06:55 AM
MILESF's Avatar
Smile
285-35 on my Z convertible. No problem. +56mm offset.
Old Jun 23, 2009 | 10:32 PM
ImportKILLER's Avatar
+2 on the 275s
No fender rub either.
Old Jun 24, 2009 | 08:23 PM
96 Z 28's Avatar
If you're worried about rubbing in the front you can also use 245/40/18s
I run 245/40s in the front and 275/35 in the rear
Old Jun 25, 2009 | 10:14 PM
What's the offset on the wheels? They appear to be aftermarket wheels, since 18x9.0 was not a factory size on any year Z06. Whether the tires will rub depends in part on the offset of the wheels, and how deep they sit in the wheel wells. Properly spaced, you should have no trouble with a 275 section-width tire of the correct diameter, since 275 section-width tires were standard equipment on the 4th Gen WS6 and SS coupes.
HectorM52
Jul 30, 2017 11:46 AM
Moshbmx1
Jan 20, 2015 03:27 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
bossco
Nov 29, 2014 10:18 AM
