help water pump?
help water pump?
whats up guys need help with this, i was in my car for like 30 mins. i came home and parked the car, did not turn it off and open the hood it throwing water all over the place so i looked under the car and water was running down the front of the block behind the crank pully. so i turned the car off and it stoped. not even a min turned it back on and let it run for 15 mins and no water any where. then i reved up the motor alot and no leak what the hell is going on. thanks guys
I'd find out exactly where the water was coming from before starting to change out parts. If you lost enough water/coolant with the leak, there's a good possibility its not leaking any more because there's no coolant left, or its so low the system won't build any pressure.
Blood type Z28
Apr 8, 2015 11:34 PM
