C5 wheels on 95 camaro
Old Apr 29, 2009 | 10:40 PM
ivandessel's Avatar
I am looking at these C5 wheels to put on my z28 1995 camaro just wondering if anyone else has put these on their camaros and if they will fit without modifing the fenders ? thanks
The wheels sizes are Rear: 275/35 zr 18 Front: 245/45 zr 17 rim fronts
http://images.craigslist.org/3kd3m03...4b4da61cd6.jpg
Old Apr 29, 2009 | 11:08 PM
What you have provided are the tire sizes, not the wheel sizes. And those are not the stock rear C5 tire sizes. They were 275/40-18.
Stock C5 wheels were 17x8.5" front, 18x9.5" rear.
The 275/35-18 tire will fit correctly on an 18x9.5" wheel, preferably with a 45-56mm offset. A stock (factory) C5 18x9.5" wheel will have a 65mm offset. It will "fit" but will sit a bit deep in the wheel well, due to the large offset. A 245/45-17 tire will fit correctly on a 17x8.5" wheel, with a 45-50mm offset. Again, the stock (factory) C5 wheel has a 58mm offset, and will sit deep in the front wheel well.
You might want to consider a 285/35-18 tire for the rear.
While the wheels have the correct bolt pattern, in order to fit the Corvette rear wheels over the over-sized axle hubs on the 93-96 F-Body, you may need to lightly sand the inside diameter of the hub hole in the back of the wheel.
Old Apr 30, 2009 | 11:16 AM
ivandessel's Avatar
when you guys talk sanding of the hub are you talking hand sanding or with a hand grinder or orbital sander? and how much would you pay for 4 wheels silver and tires with 60% tread?
Old Apr 30, 2009 | 10:07 PM
There is a round hole in the back of the wheel. You can hand sand the edges (inside diameter) of the hole, or use a dremel. The amount that has to be removed is about the thickness of a sheet of paper.
Old May 1, 2009 | 06:58 PM
Tokuzumi's Avatar
Check out the thread I just posted. Got C5 wagon wheels installed a few hours ago. They look good....to me, anyway.
https://www.camaroz28.com/forums/sho...69#post5948469
I didn't need to sand the hubs at all, because I installed 1.25" spacers on the rear, from skulte performance. I have a thread about those, as well. I chose the spacers, because the C5 wheels have about 1" greater backspacing, so the wheels would be a little closer to the inner wheel well than I want them. So, this gives me the clearance I had with stock wheels.
Old May 7, 2009 | 11:51 AM
ivandessel's Avatar
at least I have some options now thanks for the reply's, Tokuzumi those are the exact wheels I was looking at and with your photos I think I am going to make the purchase, and I will look into the spacers or the sanding will see
thanks
hotrodyou1
Dec 20, 2014 10:05 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
CaRParts102
Dec 6, 2014 08:45 AM
ChrisFrez
Nov 30, 2014 08:41 AM
