12 sec goal how
i have a 94 z28 auto with 102000 miles on it and its 100 percent stock and i want to run a 12 sec and i wanted some opinions on wut mods to do money is not important cus im doing it slow. thenks
Cold air intake, headers, catback, Tq converter, gears and tune. That should get you close depending on what your baseline is. After that you need to chose between spray or a cam. You can also reduce weight, but it takes about 100lbs to equal a tenth. get some timeslips and let us know where you stand in stock form.
In my opinion, the best way would be in this order
3.73 gears 3000+ stall, drag radials, cold air, long tubes+ exhaust, torque arm+lower control arms, sub-frame connectors, remove front sway bar, remove all the crap
dont forget the tune
Ive run 12.80 at 108 with a less than 60 hp shot of nitrous
on street tires.
I'm thinking when I get my new trans and stall Ill be in the 12s with drag radials
on street tires.
