12 sec goal how
Old Nov 5, 2008 | 08:00 PM
wichol98's Avatar
Question 12 sec goal how
i have a 94 z28 auto with 102000 miles on it and its 100 percent stock and i want to run a 12 sec and i wanted some opinions on wut mods to do money is not important cus im doing it slow. thenks
Old Nov 5, 2008 | 08:16 PM
fasteddie94's Avatar
Cold air intake, headers, catback, Tq converter, gears and tune. That should get you close depending on what your baseline is. After that you need to chose between spray or a cam. You can also reduce weight, but it takes about 100lbs to equal a tenth. get some timeslips and let us know where you stand in stock form.
Old Nov 5, 2008 | 08:21 PM
wichol98's Avatar
what gears do u think are good for me and converter to i dont know much bout them its my first auto
Old Nov 5, 2008 | 08:49 PM
bombebomb's Avatar
Overall the best gears for you would be 3.73's. If you was going strip only, then im sure a much lower gear would be better.
Old Nov 5, 2008 | 09:08 PM
LaredoZ28's Avatar
you can also go with bolt ons such as a throttle body, under drive pullies lil things like that. I'd recomend a 3200-3600 Circle D converter.
Old Nov 5, 2008 | 09:23 PM
PWR SHFT's Avatar
...and don't forget the Drag Radials!
Old Nov 5, 2008 | 11:05 PM
wichol98's Avatar
the car is not a daily driver its mostly a project
Old Nov 6, 2008 | 12:09 AM
6SpdLT1Z's Avatar
drag radials, full exhaust, and a stall. If that doesn't get you there a cam will.
Old Nov 6, 2008 | 02:12 PM
wichol98's Avatar
what times should i see before any mods 100% stock
Old Nov 6, 2008 | 02:54 PM
LaredoZ28's Avatar
Down here in south texas we hit high 13's to low 14's on lt1's 100% bone stock.
Old Nov 6, 2008 | 03:23 PM
bombebomb's Avatar
14.4~ is what I ran in ohio.
Old Nov 6, 2008 | 03:44 PM
henryz28's Avatar
Stall, drs, LT headers, cat back, CAI, Electric water pump, 1.6NSA roller rockers and a mail order tune should put you into the 12s; if the motor is running good.
Old Nov 6, 2008 | 03:51 PM
PWR SHFT's Avatar
13.80s @ 100 bone stock 94 Formula A4
Old Nov 6, 2008 | 06:34 PM
slowride94z's Avatar
In my opinion, the best way would be in this order
3.73 gears 3000+ stall, drag radials, cold air, long tubes+ exhaust, torque arm+lower control arms, sub-frame connectors, remove front sway bar, remove all the crap
dont forget the tune
Ive run 12.80 at 108 with a less than 60 hp shot of nitrous
on street tires.
I'm thinking when I get my new trans and stall Ill be in the 12s with drag radials
Old Nov 6, 2008 | 06:47 PM
1994greenz28's Avatar
With just a K&N CAI, I ran a 14.1. That was my first time in my 80,000 mile Z28. I know it would run 13.9 if I had a better reaction time.
