What to do with test knock sensor test info.?
Old Sep 26, 2008 | 07:49 PM
biggrizzly's Avatar
Tonight I tested my knock sensors because I was getting some false knock and timing retard at idle, based on datamaster scans I did yesterday. This is in a 94 Corvette that I just finished doing a LE2 H/C swap. The knock sensors were brand new from GMPP when I put the motor back together and I also installed the LT4 knock module in the PCM for good measure since I installed 1.6 roller rockers too.
Tonight I tested them as instructed on Shoebox's website.
I got voltage readings of 4.8 on both wires going to the sensors, but the wires are pretty fugged up, so I think I'm going to be replacing the connectors and wires this weekend.
I then turned off the key and ohmed out the sensors and I got 99.6k ohms on both sensors. Does this indicate that they are the wrong sensor for my 94 OBDI PCM? I think the test procedure said the OBDII cars used the higher resistance sensor?
Any comments welcome
Thanks in advance
Old Sep 26, 2008 | 10:01 PM
biggrizzly's Avatar
FOR POSTERITY
I have undisputed proof that I installed the wrong knock sensors and pulled the code 43 for having them wrong sensors.
There is no specific LT4 knock sensor. However, there are differences in the impedance of the sensors between OBD-I and II as listed in the testing section here. You must use the sensor that is matched to your OBD type (or have a wiring modification as frequently done in an OBD type swap situation)
OBD-I (1993-1995) knock sensor GM PART # 10456126 ACDelco #312-96
OBD-II (1996-1997) knock sensor GM PART # 10456287 ACDelco #213-325
I went to my account at GM parts direct and see that I ordered the wrong sensors. Anyone need OBDII sensors? I got two you can get real cheap. I hope I can find the correct ones around here tomorow.
HectorM52
Jul 30, 2017 11:46 AM
4586
Mar 18, 2015 06:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
