What to do with test knock sensor test info.?
Tonight I tested my knock sensors because I was getting some false knock and timing retard at idle, based on datamaster scans I did yesterday. This is in a 94 Corvette that I just finished doing a LE2 H/C swap. The knock sensors were brand new from GMPP when I put the motor back together and I also installed the LT4 knock module in the PCM for good measure since I installed 1.6 roller rockers too.
Tonight I tested them as instructed on Shoebox's website.
I got voltage readings of 4.8 on both wires going to the sensors, but the wires are pretty fugged up, so I think I'm going to be replacing the connectors and wires this weekend.
I then turned off the key and ohmed out the sensors and I got 99.6k ohms on both sensors. Does this indicate that they are the wrong sensor for my 94 OBDI PCM? I think the test procedure said the OBDII cars used the higher resistance sensor?
Any comments welcome
Thanks in advance
Thanks in advance
FOR POSTERITY
I have undisputed proof that I installed the wrong knock sensors and pulled the code 43 for having them wrong sensors.
I went to my account at GM parts direct and see that I ordered the wrong sensors. Anyone need OBDII sensors? I got two you can get real cheap. I hope I can find the correct ones around here tomorow.
There is no specific LT4 knock sensor. However, there are differences in the impedance of the sensors between OBD-I and II as listed in the testing section here. You must use the sensor that is matched to your OBD type (or have a wiring modification as frequently done in an OBD type swap situation)
OBD-I (1993-1995) knock sensor GM PART # 10456126 ACDelco #312-96
OBD-II (1996-1997) knock sensor GM PART # 10456287 ACDelco #213-325
carguyshu
Jan 22, 2017 11:19 AM
