gears? stall? or both
hey all decided to pull my car out of the bushes n start messin with it again and got it where i can finally drive it n was wandering something. i have a bad lugging problem in overdrive where the car seems to barely make power. up around 2500 n up it runs smooth n pulls pretty decent. so i was wandering if its more of a tuning issue or if i need lower gears or a bigger stall for my cam n head combo. i have the comp extreme 230/236, vigilante 2800, and 3.42 gears. thanks in advance for any info
I haven't figured out the exact cause yet.
OP: If this is what it's doing to you then a stall and gears won't help.
I have a built tranny/3200 stall and 3.42s and my motor is STOCK and it does this. It's a TC lockup problem.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
